Hi Troy,
I've not a big fan of those. They work differently than a standard optical encoder that puts out nice clean equally spaced encoder "steps". Instead they use software interpolation of just a few poles which results in some noise and non-linearity and pulses that come in an irregular manner. But some users have reported good results. See:
Message: 5367 |
Date: 6/29/2012 |
Subject: Re: 4:th axis combined spindle |
Ya ive seen some of others posted results, but if anyone is going to know of pros and cons of such things, I know that you would. :)
For same price i found some Heds 5500 E05 and US digital E3-1000-315-I.
The servo motor i got coming has a Tach on it, dont know any of the TACH specs yet. Can a tach be used by kflop to close the loop?
Thanks again,
Troy
> Hi Troy,
> I've not a big fan of those. They work differently than a standard optical encoder that puts out nice clean equally spaced encoder "steps". Instead they use software interpolation of just a few poles which results in some noise and non-linearity and pulses that come in an irregular manner. But some users have reported good results. See:Â
> http://tech.groups.yahoo.com/group/DynoMotion/message/4103
> From: tmday7 <brotroy7@...>
> Sent: Thursday, June 28, 2012 8:24 PM
> Subject: [DynoMotion] Re: 4:th axis combined spindle
> Tom,
> Got the starts of a 4th axis and was wondering what you think of this encoder for a DC servo with kflop closing the loop.
> http://www.amtencoder.com/Product/AMT102
> Thanks,
> Troy
> > Hi Bengt,
> > If you have a Servo as your Spindle that is very possible.ÃÂ You could use an M
> > code to execute a program in KFLOP to reconfigure yourÃÂ Coordinate SystemÃÂ to
> > either include the axis as the A axis or to not include it (have it operate as a
> > spindle).ÃÂ It might also set a global persist variable so that the Spindle.c
> > program knows what output to control as the current spindle for M3,M4,M5,S
> > commands (mill spindle or lathe spindle).ÃÂ You wouldn't need any external logic
> > board to do any switching.ÃÂ
> > If the Spindle is controlled as an axis it can easily be commanded to positions
> > as well as commanded to jog at constant speed like a Spindle.ÃÂ Also the encoder
> > position can be used to gear the Z axis for threading and rigid tapping.ÃÂ It is
> > just a matter ofÃÂ the axis is told to do.
> > ________________________________
> > From: Bengt Sjoelund <cnc@>
> > Sent: Wed, April 13, 2011 8:58:48 AM
> > Subject: [DynoMotion] 4:th axis combined spindle
> > ÃÂ
> > Hi Tom,
> > Planning for future where I want to be able to use A-axis and switch over to use
> > this axis as Spindle. Have a look at following at Youtube
> > http://www.youtube.com/watch?v=b2-Kdud7eiA&feature=BF&list=UL1xv603HHs3U&index=10
> > This for smaller parts all-in-one instead of lathe job first then mill.
> > He is using somekind of logic board to make the switch from A-axis to Spindle.
> > How can this be done with Kflop/Kanalog? I am planning to use a smallish AC
> > servo for this ~.5kW 7500 max rpm with 2:1 or 3:1 belt drive.
> > Cheers
> > Bengt
Message: 5368 |
Date: 6/29/2012 |
Hi Troy,
I thought the main attraction or the AMT encoders was cost. I thought you can get them for ~$29 where optical encoders are at least double that.
Regarding the Tach: no a tachometer measures velocity not position. It can be helpful to stabilize the servo especially when glass scales are used. But if you have a high resolution encoder on the motor shaft then motor shaft velocity can be derived from the encoder so a Tach is not really useful.
Message: 5369 |
Date: 6/29/2012 |
I found the optical cost on ebay. :) Could the Tach be usefull when using the 4th axis as a lathe spindle?
Troy
> Hi Troy,
> Sent: Friday, June 29, 2012 11:16 AM
> Hi Tom,
> Thanks again,
> Troy
> > Hi Troy,
> > ÃÂ
> > I've not a big fan of those.ÃÂ They work differently than a standard optical encoder that puts out nice clean equally spaced encoder "steps".ÃÂ Instead they use software interpolation of just a few poles which results in some noise and non-linearity and pulses that come in an irregular manner.ÃÂ But some users have reported good results.ÃÂ See:ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > From: tmday7 <brotroy7@>
> > ÃÂ
> > Tom,
> > Thanks,
> > Troy
> > > Hi Bengt,
> > > If you have a Servo as your Spindle that is very possible.ÃâàYou could use an M
> > > code to execute a program in KFLOP to reconfigure yourÃâàCoordinate SystemÃâàto
> > > spindle).ÃâàIt might also set a global persist variable so that the Spindle.c
> > > commands (mill spindle or lathe spindle).ÃâàYou wouldn't need any external logic
> > > board to do any switching.ÃâÃÂ
> > > as well as commanded to jog at constant speed like a Spindle.ÃâàAlso the encoder
> > > position can be used to gear the Z axis for threading and rigid tapping.ÃâàIt is
> > > just a matter ofÃâàthe axis is told to do.
> > > Regards
> > > ÃâÃÂ
> > > Hi Tom,
> > > Cheers
> > > Bengt
Message: 5370 |
Date: 6/29/2012 |
Hi Troy,
Not really. If you didn't have an encoder it coud be used for speed control but it wouldn't work for threading. For threading the spindle position is required. An encoder is simpler to connect and provides both position and velocity.
Message: 5371 |
Date: 6/29/2012 |
Ok. I like simpler anyhow.:) Strangely enough someone just started a post on Gecko about the same AMT encoder and its delay issues.
The US Digital iam looking at has 1000 CPR instead of the more common 1024, do you know if the 1000 might cause an issue somewhere down the road?
Troy
> Hi Troy,
> Sent: Friday, June 29, 2012 12:01 PM
> Hi Tom,
> Thanks,
> Troy
> > Hi Troy,
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > Hi Tom,
> > Thanks again,
> > Troy
> > > Hi Troy,
> > > ÃâÃÂ
> > > I've not a big fan of those.ÃâàThey work differently than a standard optical encoder that puts out nice clean equally spaced encoder "steps".ÃâàInstead they use software interpolation of just a few poles which results in some noise and non-linearity and pulses that come in an irregular manner.ÃâàBut some users have reported good results.ÃâàSee:ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Tom,
> > > Thanks,
> > > Troy
> > > > Hi Bengt,
> > > > If you have a Servo as your Spindle that is very possible.ÃÆ'ââ¬Å¡ÃâàYou could use an M
> > > > code to execute a program in KFLOP to reconfigure yourÃÆ'ââ¬Å¡ÃâàCoordinate SystemÃÆ'ââ¬Å¡Ãâàto
> > > > spindle).ÃÆ'ââ¬Å¡ÃâàIt might also set a global persist variable so that the Spindle.c
> > > > commands (mill spindle or lathe spindle).ÃÆ'ââ¬Å¡ÃâàYou wouldn't need any external logic
> > > > board to do any switching.ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > as well as commanded to jog at constant speed like a Spindle.ÃÆ'ââ¬Å¡ÃâàAlso the encoder
> > > > position can be used to gear the Z axis for threading and rigid tapping.ÃÆ'ââ¬Å¡ÃâàIt is
> > > > just a matter ofÃÆ'ââ¬Å¡Ãâàthe axis is told to do.
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Hi Tom,
> > > > Cheers
> > > > Bengt
Message: 5372 |
Date: 6/29/2012 |
Should not be a problem.
Message: 5373 |
Date: 6/29/2012 |
Nevermind, someone just bought them out from under me. >: I learn to keep my mouth shut.
> Thanks,
> Troy
> > Hi Troy,
> > Â
> > Â
> > Â
> > Hi Tom,
> > Thanks,
> > Troy
> > > Hi Troy,
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > Hi Tom,
> > > Thanks again,
> > > Troy
> > > > Hi Troy,
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > Tom,
> > > > Thanks,
> > > > Troy
> > > > > Hi Bengt,
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Hi Tom,
> > > > > Cheers
> > > > > Bengt
Message: 5374 |
Date: 6/29/2012 |
Boy, yahoo is getting slow.
Thanks much again for your priceless help and patience Tom.
Troy
> Sent: Friday, June 29, 2012 1:48 PM
> Thanks,
> Troy
> > Hi Troy,
> > ÃÂ
> > Not really.ÃÂ If you didn't have an encoder it coud be used for speed control but it wouldn't work for threading.ÃÂ For threading the spindle position is required.ÃÂ An encoder is simpler to connect and provides both position and velocity.
> > ÃÂ
> > ÃÂ
> > Hi Tom,
> > Thanks,
> > Troy
> > > Hi Troy,
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > Hi Tom,
> > > Thanks again,
> > > Troy
> > > > Hi Troy,
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > I've not a big fan of those.ÃÆ'ââ¬Å¡ÃâàThey work differently than a standard optical encoder that puts out nice clean equally spaced encoder "steps".ÃÆ'ââ¬Å¡ÃâàInstead they use software interpolation of just a few poles which results in some noise and non-linearity and pulses that come in an irregular manner.ÃÆ'ââ¬Å¡ÃâàBut some users have reported good results.ÃÆ'ââ¬Å¡ÃâàSee:ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Tom,
> > > > Thanks,
> > > > Troy
> > > > > Hi Bengt,
> > > > > If you have a Servo as your Spindle that is very possible.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâàYou could use an M
> > > > > code to execute a program in KFLOP to reconfigure yourÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâàCoordinate SystemÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâàto
> > > > > spindle).ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâàIt might also set a global persist variable so that the Spindle.c
> > > > > commands (mill spindle or lathe spindle).ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâàYou wouldn't need any external logic
> > > > > board to do any switching.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > as well as commanded to jog at constant speed like a Spindle.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâàAlso the encoder
> > > > > position can be used to gear the Z axis for threading and rigid tapping.ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâàIt is
> > > > > just a matter ofÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡Ãâàthe axis is told to do.
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'Ã'âââ¬Ã
¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Hi Tom,
> > > > > Cheers
> > > > > Bengt
Message: 5375 |
Date: 6/29/2012 |
Anyhow, would the 1000 CPR cause an issue that you know of?
Troy
> Thanks,
> Troy
> > Hi Troy,
> > Â
> > Â
> > Â
> > Hi Tom,
> > Thanks,
> > Troy
> > > Hi Troy,
> > > ÃÂ
> > > ÃÂ
> > > ÃÂ
> > > Regards
> > > ÃÂ
> > > Hi Tom,
> > > Thanks again,
> > > Troy
> > > > Hi Troy,
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > Regards
> > > > TK
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > ÃâÃÂ
> > > > Tom,
> > > > Thanks,
> > > > Troy
> > > > > Hi Bengt,
> > > > > Regards
> > > > > TK
> > > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Hi Tom,
> > > > > Cheers
> > > > > Bengt
Message: 1041 |
Date: 4/13/2011 |
Subject: 4:th axis combined spindle |
Planning for future where I want to be able to use A-axis and switch over to use this axis as Spindle. Have a look at following at Youtube
He is using somekind of logic board to make the switch from A-axis to Spindle. How can this be done with Kflop/Kanalog? I am planning to use a smallish AC servo for this ~.5kW 7500 max rpm with 2:1 or 3:1 belt drive.
Cheers
Bengt
Message: 1042 |
Date: 4/13/2011 |
Hi Bengt,
If you have a Servo as your Spindle that is very possible. You could use an M code to execute a program in KFLOP to reconfigure your Coordinate System to either include the axis as the A axis or to not include it (have it operate as a spindle). It might also set a global persist variable so that the Spindle.c program knows what output to control as the current spindle for M3,M4,M5,S commands (mill spindle or lathe spindle). You wouldn't need any external logic board to do any switching.
If the Spindle is controlled as an axis it can easily be commanded to positions as well as commanded to jog at constant speed like a Spindle. Also the encoder position can be used to gear the Z axis for threading and rigid tapping. It is just a matter of the axis is told to do.
Message: 1043 |
Date: 4/13/2011 |
I was kind of hoping you would answer like this :)
So it's back to the drawing board and see what kind of mechanics I can do for this new axis.
Cheers
Bengt
> Hi Bengt,
> board to do any switching.Â
> Hi Tom,
> Cheers
> Bengt
